Moja duma i wiara
Frame:
A2-SL custom-butted alloy w/ PowerCurve down tube, oversized seat tube, Rear triangle: A1-SL alloy w/ S-bend chainstays, post disc mount, cold-forged dropout and replaceable hanger
Fork:
SR Suntour SF13-XCM-RL w/ remote hydraulic lockout, 100mm travel
Front Derailleur:
Shimano Acera, M390, 34.9mm
Rear Derailleur:
Shimano Deore, M591 SGS, 9-speed
Number of Gears:
27
Shifters:
Shimano Alivio, M430 Rapid Fire, 9-speed
Chainset:
Shimano Alivio, M4308 Octalink
Chainrings:
44/32/22T
Bottom Bracket:
Shimano ES25 Octalink
Cassette:
Shimano HG20, 11-34T, 9-speed
Chain:
KMC X9, 9-speed
Pedals:
Alloy platform
Front Brake:
Hayes Dyno Comp, hydraulic disc, 180mm rotor
Rear Brake:
Hayes Dyno Comp, hydraulic disc, 160mm rotor
Brake Levers:
Handlebars:
Oval M100, alloy bar, 9 degrees sweep, 31.8mm diameter, 710mm wide
Stem:
Oval M213, 3D-forged alloy, 31.8mm clamp diameter, 6 degrees rise
Headset:
FSA 1 1/8" semi-integrated, caged bearings
Grips:
Oval dual-density Kraton
Rims:
Vera DPD22 rims
Front Hub:
Formula DC-20LW, 32H disc hub
Rear Hub:
Shimano M475, 32H disc hub
Front Tyre:
Hutchinson Cobra, 29″ × 2.1″, 33 tpi
Rear Tyre:
Saddle:
Oval M200 w/ satin steel rails
Seatpost:
Oval M200, alloy double-bolt micro-adjust, 31.6mm x 350mm
Weight:
31.46lbs/14.3kg
